  3. Tools needed for Analog simulation & MATLAB interface
  • Subscribers 132
  • Views 4190
Kabal
Kabal over 14 years ago
 Hello, we are using MMSIM10, IC6.14.
Right now for example, i can save waveforms from my simulation as table, and then open them in MATLAB.
 What im looking at now is, how to make a co-simulation with matlab.
I looked already at several tutorials, one of them for example about spectre RF engine. Another about SimCoupler.
Here are my questions:
1) Am i correct that SimCoupler and SpectreRF Engine are basically doing the same job, except that the SpectreRF Engine is oriented more towards RF related applications? So, basically for general analog stuff its preferred to use SimCoupler?
2) To import the SpectreRF Engine in MATLAB simulink, i basically open the spectrerf.mdl located in .../MMSIM10/tools/spectre/simulink,   now where is the .mdl file for SimCoupler located? I cant find it within IC614 install folder, do i need to install some another tool?  I see the AMS Designer product talking about same stuff... is that what i need to install? If yes, then what is its short name in the install directory list?
  • Kabal
     so is there anyone who could tell me at least something about how can i load SimCouplerModule from IC614?
    I saw today, if im correct, the AMS is actually a part of the whole IC design package.
    Im wondering how come i am able to find that SimCouplerModule.mdl file in older version of Cadence in the  /cadence/ic613/tools/dfII/samples/AMS/Matlab/mexFiles   but i cannot find it anywhere within IC614 install directory?
    There are two interfaces to Simulink. One from AMS Designer (that's the "SimCoupler" you are referring to; this is provided in the INCISIV stream these days), and one from Spectre.
    The AMS Designer interface is for mixed-signal simulation - although that could be entirely analog.
    The spectre interface was provided by the SpectreRF team and may be used with transient or envelope simulation.
    So in practice the spectre interface would be the one to use for normal Analog simulation.
    For the AMS simulink interface, look at <ICinstDir>/doc/amsdMatSim/amsdMatSim.pdf which talks through the tutorial; the database is at <ICinstDir>/tools/dfII/samples/tutorials/AMS/MATLABCosimulation.tar.gz
    For the spectre simulink interface, look at  <MMSIMinstDir>/spectreRF/spectreRF.pdf (there's a chapter on it - chapter 10 in MMSIM10.1). For the tutorial, look in <MMSIMinstDir>/tools/spectre/examples/SpectreRF_workshop and there's SpectreRF_simulink_example.pdf and SpectreRF_simulink_example.tar.Z - a pdf and the database to try it out.
  • KBragin
    KBragin over 13 years ago
    Hello, Andrew!
    Thank you for advice.
     We use matlab 2012a/b. Modern versions of matlab doesn't support 32 bit platforms.
    Mex library SimCoupler.mexglx from MATLABCosimulation.tar.gz was compiled for matlab 2007b 32-bit version.
    Can we expect new version SimCoupler.mexglx for 64-bit version?
    Don't use the version in that tar file - it's really old.
    The official versions are shipped with the INCISIV releases - for example in:
    <INCISIVinstDir>/tools.lnx86/affirma_ams/etc/matlab
    There are both 32 bit and 64 bit versions of the mex files there (certainly in INCISIV11.1 INCISIV12.1 and INCISIV12.2 - I didn't check earlier versions).
