  3. Problem with tran.tran file size
  • Views 16749
DineshBabu
DineshBabu over 14 years ago
Hello All,
 I am running an APS simulation.
Every time when the tran.tran file size is more than 2GB, the tool automatically splits it up into many files, each with a maximum file size of 2GB.
However, when I choose "tran->compression=yes", it doesn't split up anymore, but, it stops when the file size is 2GB.
I would like to know why it stops.
Thanks in advance!
  • tkhan
    tkhan over 14 years ago
    misread the question
  • Frank Wiedmann
    Frank Wiedmann over 14 years ago
    It stops because 2 GB is the maximum file size on 32-bit Linux (see for example http://linuxmafia.com/faq/VALinux-kb/2gb-filesize-limit.html).
  • DineshBabu
    Thanks for your reply, Frank!
    As I have chosen compression=yes, the file doesn't split up anymore once the file size reaches 2 GB
