  3. pcell problem
  • Subscribers 133
  • Views 15208
pcell problem
Stefan Bormann
Stefan Bormann over 14 years ago
I have the following question.
I updated our pdk (tsmc process) with some addons for rf devices and minor techlib tweaks.
We have some special capacitors  (crtmom). The pcell for this is working good, but
if I open an old layout with pcells from before the chance I miss some layers (VIA2 and MET2).
The strange things is this:
In the same layout I have both types of the layouts (created by the pcell before and after the change).
1) copying/editing the new one all is correct, also if I insert it from the techlib as a new part.
2) copying/editing the old oneit still have the old layout (without MET2 / VIA2) inserting a part again from the techlib (the same cell as in step1) it comes with the wrong layout (without MET2/VIA2)
 copying cell to another cell with different name doesn't help.
that means replacing  hierachical is not working.
Any ideas how I can virtuoso force to use the correct pcell?
Thanks in advance.
-Stefan
  • Stefan Bormann
    I found the error,
    I had to rerun a tsmc script on the pdk library to generate the pcells.
    So the problem was the pcell.
    Now it is working as it should.
    Regards
    -Stefan
