  3. How to find some parameters of OTA
  • Subscribers 136
  • Views 18248
ralakhani
ralakhani over 14 years ago
hello everyone,
I want to find some parameters like gain, phase, bandwidth, gain bandwidth product, unity gain bandwidth, CMRR, PSRR, slew rate. how can i find?
is test bench required for it?
Thanks in advance
  • ralakhani
    hello everyone,
    Thanks in advance.
  • Quek
    Quek over 14 years ago
    Hi Ralakhani
    You can use "Tools->Calculator" in ADE-L to do it. A test-bench is required. First do the necessary setup (e.g. add ac sources, etc), run spectre simulation then use calculator functions to do it. E.g.
    Gain : Use "VF" to get the wave object then use "value" at 1 Hz to get the DCgain.
    Bandwidth : Use "bandwidth" function
    Phase : Use "phase" function
    etc
    Best regards
    Quek
  • abhigoyal
    abhigoyal over 12 years ago
    hi
    i want to know what is the procidure to calculate CMRR of OTA.
  • abhigoyal
    hi;
    i am designing an OTA for EEG signals but i am not getting required gain so what should i do ??
  • Quek
    Quek over 12 years ago
    Hi abhigoyal
    Would you please start your new thread for your own question?
    Quek
