  3. Cannot open saved graphs, IC6.14
  • Subscribers 133
  • Views 14900
Kabal
Kabal over 14 years ago
 When i run some simulation, i can save graph in its .grf format and then open it.
But for some reason, when i copye my library to another machine, and try to open the .grf files with waveform it spits out error like this:
- Warning -
<COM.cadence.awd.graph.GraphManager@64af1f>
 Problem while loading data for trace: *
/home/kabal/simulation/rlib180/amplifier_cd_test1_tb/adexl/results/data/Interactive.40/1/rlib180:amplifier_cd_test1_tb:1/psf:dc-dc:vout1
 I dont understand why? The file is there, im just trying to open it. Sometimes this happens on the same machine on which it was saved. For example, if i save the graph, then restart cadence, and then run another simulation, but want to open old saved graphs it gives same error.
any ideas why?
    Reloading graph files in IC614 (particularly with ADE XL) is problematic, because the paths often will have changed. I don't know the real reason, but moving to IC615 (later hotfixes) should be better (the graph is completely new in IC615 too, and much improved).
    IC614 is not a supported release any more.
