  3. VCAR - Routing Specified Nets
  • Replies 12
  • Subscribers 133
  • Views 7274
sPoK
sPoK over 14 years ago
I've read the iccraft documentation but there is no info how to export selected nets from layout to a netlist file requested by VCAR.
There is only this note:
Note: Virtuoso Chip Assembly Router does not support extracting netlists from schematics, CDL, or HSpice. Use Virtuoso XL to ensure the layout netlist is populated.
So, how to do this, please?
I'm using 6.1.5 version.
    I don't know either - because I tried one with a bussed net. You might want to use some of the reporting capability in VCAR (without -nets supplied) to see what the net names are in the design in case they've been mapped somehow (seems strange though).
    You probably can log a service request via the company for whom you are contracting.
  • sPoK
    Finally I got it!
    Bussed net name in nets.txt file must be in the following format:
    bus_net[0]
    bus_net[1]
    bus_net[31]
    instead of:
    bus_net<0>
    bus_net<1>
    bus_net<31>
    and every bit of a bus must be stated.
    Thanks for the hint Andrew.
    BR
