  3. expression to access dc op info in ADE
  • Subscribers 133
  • Views 14530
ellarguero
ellarguero over 14 years ago
hello
a basic question, about ADE
i want to run a parametric dc simulation, and see the region parameter of a given transistor for the different values of the parameter.
is there an expression to retrieve this info instead of using the gui each time and swweping by hand
more broadly , how can we access a given  dc operating point data as an expression in ADE, so that it can be plotted over a parameter change
thank you
regards
  • ellarguero
    SOLVED
