  3. Assura check the presence/absece of derived layer in if...
  • Subscribers 133
  • Views 1726
Assura check the presence/absece of derived layer in if( )?
clmok
clmok over 14 years ago
Hi..
I am using Assura (4.1_USR2_HF10) for physical verification (with IC615). I wonder someone is using any work-around/alternative way to check the presence/absence of derived layer (dfII or gds) in if() function despite the tool contraint to check derived layer existing. For example.
if( derived_layer then
   presence, execute procedure-A
else
   empty, execute procedure-B
);if
Thanks.
Best regards
Mok
  • Quek
    Quek over 14 years ago
    Hi Mok
    You can use this:
    A = /* some layer operations */
    B = /* some other layer operations */
    bgnd = geomBkgnd()
    C = geomOverlap( bgnd A )	    ; empty if A is empty, everywhere if A is
    not empty
    D = geomOutside( bgnd A )	    ; empty if A is not empty, everywhere if A
    is empty
    E = geomAnd( A C )			   ; empty if A is empty, otherwise
    this equals A
    F = geomAnd( B D )			   ; empty if A is not empty, otherwise
    this equals B
    OUT = geomOr( E F )			 ; equals A if A is not empty , equals
    B if A is empty
    If layer A is not empty, layer OUT should equal layer A.
    But if layer A is empty, layer OUT should equal layer B.
    Best regards
    Quek
  • clmok
    Hi Quek,
    Thank you for your suggestion.
    Best regards,
    Mok
