  3. how to perform post layout simulation?
  • Subscribers 136
  • Views 20008
ralakhani
ralakhani over 14 years ago
hello sir, nobody is in my college to guide me, no supervisor here.
please tell me what to do for post layout simulation after performing successfully LVS.
And also give me idea about how can i generate test bench of OTA design?
in my OTA design i want to apply both differential voltage(ac sin input) and input common mode voltage simultaneously how can i apply in layout, in schematic i have used ideal balun but what to do for layout?
please help me.
thanks a lot in advance.
  • Quek
    Quek over 14 years ago
    Hi ralakhani
    Here is how you can do a post layout simulation:
    a. First create your layout
    b. Run Assura or PVS LVS on the layout
    c. Run QRC to generate an extracted view
    d. Create a schematic test-bench for the cell
    e. Create a config view for the test-bench and set the view for the cell to the extracted view
    f. Run ADE-L using the config view
    For the OTA testbench question, I think perhaps it might be better if you post it in the designer's guide forum.
    Best regards
    Quek
  • sohaibafridi
    sohaibafridi over 14 years ago
     Dear Quek,
    Please could you elaborate a big on config view. How to create it and what is its purpose?. Sorry I am new to Cadence and was following this post because I was looking for an answer for the same issue as Mr. Ralakhani is facing.
    Regards
  • Quek
    Hi Sohaibafridi
    Would you please start a new thread for your question? Thanks.
    Best regards
    Quek
