  3. set design variables in ADE XL
  • Subscribers 132
  • Views 18503
nzborsti
nzborsti over 14 years ago
I am new to Cadence and I am using ADE XL (Version IC6.1.4.500.6)  for the first time.
I wrote a simple model for a low-pass-filter by means of verilog ams. This model  includes some paremeters such as "nst_0","pst_r" etc.
These paramters show up, when I open the" Edit Object Properties" of the low pass filter, in the schematic of my testbench.
Now I want to start a simulation of this testbench by means of ADE XL. To do this I also wanted to add the parameters "nst_0" to the "design Variables".  How is that done?
I already tried to assign a string " nst" to the value of "nst_0" in the "edit Object Properties" Window. After that I added a Design Variable in the Virtuoso ADE XL window named "nst" and assigned a value to this variable. But this didn't do the job cause everytime I hit the simulate button a error comes up:
ncelab: *E,CUBSPA (./netlist.vams,22|22): Assignment of string to real or integer type parameter.
I am looking forward to your help.
Sebastian
  • nzborsti
    I am still dealing with the problem I discribed earlier on but made some progress.
    By looking into the netlist.vams and cds_globals.vams I figured out the following:
    Each variable I add is listed in the cds_globals.vams  for example when using the vsource in a schematic and I assign Phase to  Initial phase for Sinusoid the entry in the cds_globals.vams looks somewhat like this:
    // Verilog-AMS cds_globals module for top-level cell:
    //    test/testbench_PLL2.
    // Generated by ADE.
    // Cadence Design Systems, Inc.
    // This is an autoGenerated file, any changes done to this file may get lost.
    `include "disciplines.vams"
    `include "userDisciplines.vams"
    module cds_globals;
    // Global Signals
       electrical \gnd! ;
       ground \gnd! ;
    // Design Variables
       dynamicparam real Phase = -90;
    endmodule
    And the  associated netlist.vams looks like this.
    // AMS netlist generated by the OSS based AMS netlister
    // IC subversion:  IC6.1.4.500.6
    // IUS version: 09.20-s022
    // Copyright(C) 2005-2009, Cadence Design Systems, Inc
    // User: seth3685 Pid: 22606
    // Design library name: test
    // Design cell name: testbench_PLL2
    // Design view name: config
    // Solver: Spectre
    // Library - test, Cell - testbench_PLL2, View - schematic
    // LAST TIME SAVED: Apr 23 08:29:20 2012
    // NETLIST TIME: Apr 23 08:29:27 2012
    `timescale 1ns / 1ps
    (* cds_ams_schematic *)
    module testbench_PLL2 ();
    vsource #(.mag(1), .type("sine"), .sinephase(cds_globals.Phase),
        .freq(150K)) V0 (Sig_in, cds_globals.\gnd! );
     endmodule
    But when I use my verilog ams models in a schematic (e.g the VCO2 ) and I assign Ampl to the output amplitude of the VCO signal the netlist.vams looks different in one point. It looks like this:
    VCO2 #( .Fmin(97.48k), .Fmax(102.52k), .ampl("Ampl"), .Vmax(6), .Vmin(0)
        , .Fo(100K) ) I4 ( .out(VCO_out), .in(TP_out));
    So has anyone an idea how to solve this? I can I get ade xl to wirte  .ampl(cds_globals.Ampl) instead of .ampl("Ampl")?
    Looking forward to your replies
  • nzborsti
    okay problem is solved. For the sake of completness I would like to tell you , how I have managed to get around this problem:
    1) open the CDF Tool
    2) Open the corresponding module: scope: "cell " in the  CDF layer "base"
    3) enable " parse as number" option
    4) Open ADE XL and add the Design Varibles you have included in your  Verilog AMS Code
    And that should do the job.
    Bye Bye
    Ps: This is how the cdfDump file looks like now:
      cdfCreateParam( cdfId
            ?name           "Fo"
            ?prompt         "Fo"
            ?defValue       "4.5e+07"
            ?type           "string"
            ?display        "artParameterInToolDisplay('Fo)"
            ?parseAsNumber  "yes"
            ?parseAsCEL     "yes"
