  3. dbCreateParamInst
  • Subscribers 132
  • Views 16092
dbCreateParamInst
ghost
ghost over 14 years ago
Hi friends,
I am using dbCreateParamInst() function to instantiate a pcell.
dbCreateParamInst(cv cv2 "" xy "R0" 1 list( list("w" "float" W1) list("l" "float" L1) ))
It is giving me the following error:
 *WARNING* (DB-270000): dbCreateParamInst: Datatype for input parameter 'w' does not match the definition
Can anyone suggest a solution or alternative usage.
Ajay
    Ajay,
    My guess is that it's expecting  a string type - that entirely depends on how the pcell has been defined. You can check by doing:
    dbFindProp(cv2~>parameters "w")~>valueType
    This will tell you the type that the "w" parameter has been defined with on the pcell master.
  • ghost
    Thanks. You are right. It is expecting a string.
    Will proceed likewise.
    BR
    Ajay
