  3. Running Cadence IC on VMware?
  • Subscribers 133
  • Views 20862
John Reeder
John Reeder over 14 years ago
 My IT department is very enthusastic about putting everything on VMware.  They say that this will make their job much easier.
I would like to know if you, anyone, or your company has tried running Cadence IC, ADE, or Virtuososo (any version) on VMware and how it worked out for you.
  • Quek
    Quek over 14 years ago
    Hi John
    Apart from the license server which does not work no a virtual machine, Cadence tools (e.g. Virtuoso, Encounter, etc) has no problem operating on vmware. I am using IC615-500-9 on VMware workstation 6.0.2.
    Best regards
    Quek
  • skillUser
    skillUser over 14 years ago
    Hi John,
    In addition to what Quek said, I don't think that VMware is officially supported.  However, having said this, if the virtual machine is a supported OS (e.g. RedHat 5.3, say, or SuSE 10 etc.) for the releases of tools that you are using, you should be successful.  The tricky thing is the licensing.  I believe that you can run the licenses directly on the base system and allow the VMware sessions to access the licenses.  It is not supported to actually serve licenses from a virtual machine though.
    Hope this helps!
    Lawrence.
  • John Reeder
    Thank you for sharing your thoughts on this.
    I have heard from some people that running Cadence on VMware caused their applications to sometimes hang or crash.
    And in general there was about a 20% overall decrease in performance.
    However, I am still finding out more.
    John
  • Quek
    Hi John
    I think it is extremely hard to quantify "performance" because it is denpendent on specific virtual operating systems and also on the setup. I have been using vmware workstation for 7 years and so far everything works great. : )
    Best regards
    Quek
