  3. Effect of load capacitor at the output of an oscillator
  • Subscribers 133
  • Views 15808
Jithin
Jithin over 14 years ago
While designing an oscillator ,which had a ring oscillator(differential ended) architecture , the frequency sensitivity of the vco had changed, that is if initially my vco works in a frequency range of 300MHz - 500MHz aor a control voltage range (1.3V-1.85V). After adding a capacitor
at the output,say 400fF of each differential amplifier stage then the same frequency(300MHz- 500MHz) swings at a voltage range of (.9V - 1.65V).Thereby decreasing the  gain of vco. The problem is that I can't find a reason for this phenomenon and can't answer the questions like how the range of the control voltage had changed due to the addition of a load capacitor.
Please help me.
Thanking you in advance.
with regards,
Jithin
  • Quek
    Quek over 14 years ago
    Hi Jithin
    It seems that this is a design issue and it would be a little hard for us to help. : )  Hope that you will be able to get more help in the designer's forum.
    Best regards
    Quek
    Especially without seeing the design - you didn't even say how the control voltage controls the VCO frequency, for example. But Quek's right - a more design-centric forum would probably make more sense.
  • Jithin
    Thank you Andrew .
