  3. turning off net name display
  • Subscribers 132
  • Views 21056
linbo
linbo over 14 years ago
 We've just started using a design kit from a new vendor and I'm trying to make our schematics display the same information as our previous design kits.
I'm having issues with the net name display.  I've never had to fiddle with this before and cannot find the setting/variable to turn off the net name display in schematics.  Our old design kit had this turned off by default.
 Does anyone know where to look for this?
--lin
  • skillUser
    skillUser over 14 years ago
     Hi Lin,
    There is a library level CDF setting that you could set for the design library (Tools - CDF - Edit, Scope=Library, Level=Base, Interpreted Labels section, Terminals(cdsTerm) ) choose "None" to not display the Net Name next to the terminals, where the symbol would have a cdsTerm() expression in it. (I'm assuming IC61x here - the form is different in IC5141 but the approach is the same).
    Hopefully this answers your question?
    Best regards,
    Lawrence.
  • linbo
     Hi Lawrence,
     Dang, I was afraid you would say something like a library setting.  This is problematic because we're using synchronicity for revision control.
    I tested this by checking out the cdsinfo.tag then setting the cdsTerm labels to None but that didn't do the trick.  Do you know which library file that I need to be able to access, i.e. where the cdf information is stored?  The only other places I know to look are .oalib and data.dm (both of which I didn't have write permission for my little test).
     Thank you!
    --lin
  • skillUser
    Hi Lin,
    well you can make this change in virtual memory only, by choosing  "User" for the "CDF Layer" - Base + User => Effective.  The Base is stored on disk (data.dm files in IC61x, prop.xx files in IC5141 and earlier). Try setting it on the form for the User 'layer' and see if that helps.  This information is lost when you close the session, but you can probably find a way to automate it and add this setting through SKILL (e.g. cdfCreateUserLibCDF() and so on) - make the changes graphically and then Save to a file from the Edit CDF form.
    Hope this helps!
    Lawrence.
  • linbo
     Hi Lawrence,
    I tried the "User" but it didn't work, only the "Base" on a library I had full write permission for.  I think our group wants to make this change permanent anyway so I'll just have to get our recalcitrant users to check in all the files, including data.dm's.
    Thank you,
    --lin
  • skillUser
    Hi Lin,
    I didn't test this, but I would expect to be able to do it in VM only with the User layer of CDF.  Anyway, you are correct that the permanent way to do this is to write it in the library's data.dm file.  Good luck getting those users in order!
    Lawrence.
