  3. Working with tabs in virtuoso schematic editor (opus 6.1...
  • Replies 7
  • Subscribers 132
  • Views 5443
Working with tabs in virtuoso schematic editor (opus 6.1.5 - ADE L)
Aldo2
Aldo2 over 14 years ago
I'm using opus 6.1.5. When I simulate my circuits I use to open the subcircuits in different tabs.
When I want to plot some waveforms of one of the subcircuits, I open Results->Direct Plot, on ADE L form, but the focus of virtuoso schematic editor goes to the main circuit; this is very tedious.
Is there a way to block the schematic editor on the subckt/tab I'm working on, when results are plotted from ADE L?
Thank you very much
Aldo
    Aldo,
    There were some fixes related to this in IC615 ISR10, so hopefully those will solve your problem. If not, please go via customer support - it should not behave this way.
  • Aldo2
    Thank you Andrew for your help. I have another question on symbols in virtuoso schematic editor 6.1.5: I do not find the magnification field that in opus 5.x.x is visible in the 'Edit Object Properties' form when 'system' field is checked. Than you very much Regards Aldo
  • skillUser
    skillUser over 14 years ago
    Hi Aldo,
    The "mag" or "magnification" property is not a feature of the OpenAccess database, and hence objects and instances etc. in IC61x do not show this attribute or property.
    Hopefully this answers your question.
    Lawrence.
    Although there's a workaround provided - you can use the dbCreateXformPCell() SKILL function to create a "symbol_xform" view which can be instantiated in lieu of the normal symbol (you'll see analogLib components have this) - these have a mag parameter so that  you can scale up the symbol.
  • Aldo2
    Hello Lawrence, thank you for your answer!
    Hello Andrew,
    I tried to istantiate an analogLib resistor (symbol_xform view), but I couldn't find the mag field on the form. Do I have to add it as a property?
    Thank you very much
    Best Regards
    Aldo
    Aldo,
    Sorry, I forgot - this view is primarily there to allow you to migrate existing designs from IC5141. The CDF doesn't contain a parameter "mag". You can't add it as a user-defined property, because "mag" is a reserved name.
    The way to do it is to add it, and then call geQuerySelSet() - from there you can change the "mag".
    In general I'd advise against using it though for anything new.
  • Aldo2
    Many thanks Andrew, it works fine!
    Best regards
    Aldo
