  3. Recovering a graph after simulation is frozen, IC614, M...
  • Subscribers 132
  • Views 14514
Recovering a graph after simulation is frozen, IC614, MMSIM10
Kabal
Kabal over 14 years ago
When i run some simulation which takes really long time, for some reason after that time i see that the whole Cadence tools are just frozen! I browse to simulation folder of specific cell, and it has already 23GB space...so lots of data has already been recorded.
 now question is, can i somehow after the tool restart navigate to that folder and pop up the graph?
(the graph has not been saved of course in .grp format, but since the folder has 23GB the data must have been stored somehow! so how can i read at least what is saved?
    If this is ADE L, you'd open ADE L, load the state, and then do Results->Select. If ADE XL, you'd go to the history tab in the data view assistant, go over the relevant history item, and then do right mouse->View results.
    Or you can use ViVA, and open the results by navigating to the folder and plotting via the results browser.
