  3. Global Variable deletion in ADEXL
  • Subscribers 132
  • Views 17476
mailavj
mailavj over 14 years ago
Hello
 Could some one please help me regarding global variable deletion in ADE-XL.
When i right click on a variable, its greyed out
I am using IC614
 Thanks and Regards
Aravind
    You cannot delete a global variable if it is used as a local variable in one of the tests. Delete it from all tests that are using it first, then you'll be able to delete it from the global variables.
  • mailavj
     Hello Andrew
     Thank you very much
    It worked for me after deleting all local variables.
    Regards
    Aravind
