  3. ERROR (OSSHNL-116): Unable to descend into any of the views...
  • Views 9605
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'spectre cmos_sch cmos.sch schematic veriloga'
Usman001
Usman001 over 14 years ago
I have made an opamp using modelwriter and made a symbol view of it and now I am trying to test it in a feedback configuration in a testbench. But as I am trying to simulate it the simulator shows the subject error. i,e, ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'spectre cmos_sch cmos.sch schematic veriloga', for the
instance 'I10' in cell 'tb_opamp_ac'. Either add one of these views to the library 'auxiliary',
cell 'opampop_MW' or modify the view list to contain an existing view.
 Although the in ADE > setup> environment all of the switch and stop views are properly defined as said in the post the Ref. "Cadence 6.1.0 NCSU kit error :ERROR (OSSHNL-116)". Even though I have checked and defined in the Cross View Check of the symbol view but it doesn't help.
I am using Virtuoso Schematic Editor IC6.1.5-64b.500.7.
Please see the attachment as well.
BR
//USMAN
  • Quek
    Quek over 14 years ago
    Hi Usman
    Would you please let us know the views which your opamp cell has?
    Best regards
    Quek
  • Usman001
    Hi Quek,
    If you are talking about the opamp cell views in Library Manager, then they are symbol and verilogA. Also if I open its symbol and hit X to see the cross views to check, they are set to default; whereas I have tried to add spectre and verilogA view there as well but it doesn't help.
    Best Regards,
    USMAN
