  3. TAP cell in 28nm Kit
  • Views 17398
cupidsd
cupidsd over 14 years ago
We are designing a 28nm test chip, but right now we run into a problem about tap cells. In order to make a good ohmic contact for wells, we usually add well contacts, which requires additional active regions. But this is not the case in 28nm. Instead, tap cells are recommended. But I do not know the max distance between these tap cells, and how to use them. I guess it is defined somewhere in PDK, so can you help us find out this? Thanks a lot. By the way, can we use these tap cells for both NMOS and PMOS transistors?
  • Quek
    Quek over 14 years ago
    Hi cupidsd
    Perhaps you can place 2 tap cells very far apart (e.g. 100um) in a layout and run a drc check. The drc rule will most likely let you know the max distance for the tap cells.
    It would be best to consult the foundry support centre on whether it is ok to use the tap cells for both nmos and pmos devices.
    Best regards
    Quek
  • cupidsd
    Thanks  a lot, Quek.
    Thats what i ususally do, trial and error. :)
    But the issue for me is i did not find any TAP cells. Actually I have no idea what these cells look like. I found a layer named TAP, which is like METAL1. Its only a layer, so how to use it in our design? If its only a layer, how does it work, im quite curious.
    Thanks again.
  • Quek
    Hi cupidsd
    Then I am afraid that this is a little difficult to help on this. I think it is best to contact your foundry support centre. : )
    Best regards
    Quek
