  3. The way to build my own capacitors/resistors
  • Subscribers 132
  • Views 1053
DWalter
DWalter over 14 years ago
I need to build my own capacitors which can be recognised in the extraction. As far as I know we need do the LVS check at first whereas there is no schematic....
Then I want to ask several questions:
1   How can we define the terminals of a capacitor which can be mapped to a netlist/schematic/script?
2   Many PDKs' caps have the 3rd terminal which should be connected VDD/VSS. Should I consider this too? My cap is only 2 metal plates from the toppest.
2   How can we do the Extraction. In my case, RCX did not work since something is not defined in LVS file, which I cant run.
 If who can share a designflow of this kind of thing, that's would be great.
 My enviorment is assura/ic6.
Thanks for you attention!
