  3. IC package choice
  • Replies 11
  • Subscribers 133
  • Views 19475
IC package choice
pyohayo
pyohayo over 14 years ago
What package(s) have all necessary tools to effectuate the following tasks:
  1. Schematic Editor (NECESSARY)
  2. Digital simulation (NECESSARY)
  3. Digital synthesis (NECESSARY)
  4. Placement/routing (NECESSARY)
  5. Test vector generator (NECESSARY)
  6. Mixed-mode simulation (OPTIONAL)
The design kit is made for Cadence v.5.
Thanks in advance,
Pavel.
  • Quek
    Quek over 14 years ago
    Hi Pavel
    Here is the info:
    1. IC5141
    2. INCISIVE
    3. RC
    4. EDI
    5. INCISIVE
    6. INCISIVE
    Best regards
    Quek
  • pyohayo
    Hi Quek
     Thanks. Are RC and EDI both inside of SoC Encounter, or they persent separate packages ?
    Is mmsim (7.1 , 10.1) just replacement for INCISIVE, or it's completely different package ?
    Pavel.
  • Quek
    Hi Pavel
    RC is a separate package from EDI. MMSIM is not a replacement for INCISIVE. It is a completely different package.
    Best regards
    Quek
  • pyohayo
    Hi Quek,
    Thanks for response.
    Is RC is only package for synthesis ? What tasks covers SoC Encounter ?
    Is INCISIVE is only package for digital/mixed-mode simulation. As I've heard mmsim also includes simulators.
    Regards.
    Pavel.
  • Quek
    Hi Pavel
    Yes, RC is the only package for synthesis. EDI is for digital place and route. INCISIVE is the only package for digital/mixed-mode simulatoin. MMSIM is for analog simulation.
    Best regards
    Quek
  • pyohayo
    Hi Quek,
     Thanks. Clear. Only one point - I've seen a lot of pests, where IC5141 is installed together with mmsim 7.1.
    According to you mmsim is only for analog simulations. But IC5141 includes already Spectre.
    What sense to have 2 analog simulators ?
    Pavel.
  • Quek
    Hi Pavel
    Spectre in IC5141 is already obsoleted. Only spectre in MMSIM should be used.
    Best regards
    Quek
  • pyohayo
    Thanks Quek. In order to have full clarity could you, please, clarify 2 points:
    1. Besides Spectre what else tools includes mmsim
    2. What tasks cover SoC Encounter
    Regards.
    Pavel.
  • pyohayo
    It means when one instals new USR (3,4,5,6 which one), the Spectre in basic package is simply suppressed ?
    Or user must configure which version of Spectre must be used - from IC5141(Basic) or from mmsim ?
    Regards.
    Pavel.
  • Quek
    Hi Pavel
    You have to ensure that the path for MMSIM comes before IC5141 in your .cshrc file so that MMSIM spectre and not IC5141 spectre will be used. MMSIM also contains ultrasim fastspice simulator. EDI package is needed for standard cell placement and routing.
    You can also refer to www.cadence.com for more detail on the packages. : )
    Best regards
    Quek
