  3. Converting mosaic of syContacts devices from IC5 to IC6...
  • Subscribers 132
  • Views 14951
Converting mosaic of syContacts devices from IC5 to IC6 ( cdb2oa )
bnugent
bnugent over 14 years ago
Hello all,
I have been converting some old designs over from IC5.1 to IC6.1.4.500 and I've found that the via definitions have changed a lot. This is the first time I've had to use the cdb2oa gui, and the conversions were fairly straightforward with one exception. I encounter this warning:
"WARNING CDBOA-644 -- The cellview <cell_view_name> contains a mosaic of syContact devices. The translator does not   recognize the member instances of this mosaic as vias. So, the mosaic will be translated as a mosaic of regular instances."
I have filed an SR because I haven't found any discussion on this error on the forums. Has anyone encountered this issue and more importantly has anyone found a solution to this? I'd appreciate any feedback on this issue.
 Cheers,
-Brian N.
    Brian,
    I see that you're having a lot of discussion with customer support via SR 42894256 so I won't duplicate the effort of my colleagues in support and try to answer this here.
    Kind Regards,
  • bnugent
    Andrew,
    I am having a discussion with customer support and it has been pretty helpful. I didn't realize how differently vias were defined. It appears that I will have to manually fix all of the mosaic of vias because of how they were laid out in IC5.1. Thanks for replying.
    Cheers,
    Brian
