  3. IC5141 on RHEL5 64bit
  • Views 19074
pyohayo
pyohayo over 14 years ago
Can IC5141 work on RHEL5 64bit ?
Pavel.
  • Quek
    Quek over 14 years ago
    Hi Pavel
    Yes, it works. Only "layout" executable works in 64bits. The rest will remain in 32bits on the 64bits OS.
    Best regards
    Quek
  • pyohayo
    Hi Quek,
    Thank you for response.
    When I try to run icfb, it doesn't work and following error message appears:
     /opt/cadence/IC5141/tools/dfII/bin/icfb.exe: relocation error: /opt/cadence/IC5141/tools/dfII/bin/icfb.exe: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
    There are 2 versions of the file libc.so.6 on my system: first in the /lib directory and second is in the /lib64 directory. In the /lib/libc.so.6 the GLIBC_2.0 is defined:
    Here is the ouput of strings /lib/libc.so.6 | grep GLIBC :
    GLIBC_2.0
    GLIBC_2.1
    GLIBC_2.1.1
    GLIBC_2.1.2
    GLIBC_2.1.3
    GLIBC_2.2
    GLIBC_2.2.1
    GLIBC_2.2.2
    GLIBC_2.2.3
    GLIBC_2.2.4
    GLIBC_2.2.6
    GLIBC_2.3
    GLIBC_2.3.2
    GLIBC_2.3.3
    GLIBC_2.3.4
    GLIBC_2.4
    GLIBC_2.5
    GLIBC_PRIVATE
    The 64bit version of the libc.so.6 indeed doesn't define GLIBC_2.0:
    strings /lib64/libc.so.6 | grep GLIBC
    GLIBC_2.2.5
    GLIBC_2.2.6
    GLIBC_2.3
    GLIBC_2.3.2
    GLIBC_2.3.3
    GLIBC_2.3.4
    GLIBC_2.4
    GLIBC_2.5
    GLIBC_PRIVATE
    When I check shared libraries,  I see that it's 64-version of the libc.so.6, that is used. Here is the result of the ldd /bin/bash command:
            libtermcap.so.2 => /lib64/libtermcap.so.2 (0x0000003f8ac00000)
            libdl.so.2 => /lib64/libdl.so.2 (0x0000003f8a800000)
            libc.so.6 => /lib64/libc.so.6 (0x0000003f8a000000)
            /lib64/ld-linux-x86-64.so.2 (0x0000003f89c00000)
    It seems that icfb is wired to 64bit version of the libc.so.6, that doesn't define GLIBC_2.0.What could be solution of the problem. How to redirect icfb to 32bit version of the libc.so.6.
    My linux kernel is 2.6.18-164.11.1.el5. For compatibility with old kerneIs I also included following command in .bashrc file:
    export XD_ASSUME_KERNEL=2.4.1
    Regards.
    Pavel.
    Pavel,
    I only see that error if using a really old version of IC5141 (e.g. the Base CD version, or USR1). Using USR6 or a recent hotfix works fine. You should make sure you're using a recent enough build.
    I have been running IC5141 on RHEL5 for about 4.5 years or so, and the only real issue is with cdsdoc (there's a solution on Cadence Online Support for how to make that work too, which I wrote). That said, IC5141 is not actually supported on RHEL5 (which means it is not tested on that OS) - but in practice, it woks fine.
    By the way, the XD_ASSUME_KERNEL won't do anything, I believe, because it should be LD_ASSUME_KERNEL. However, you should not set that on RHEL5 because all sorts of things will break if you do that!
  • pyohayo
    Andrew, thank you for response.
    What upgrade is better - USR or hotfix (ISR, QSR). As I've heared only USRs modifications are 100% tested. But ISRs are more recent - the last USR - USR6 dates 2008, whereas there were ISRs in 2009 (or even later).
    Pavel.
    Pavel,
    I would suggest that the latest ISR is the most sensible - there have been a lot of fixes over the intervening 3-4 years since the last USR.
  • pyohayo
    Ok, thank you Andrew.
