  3. Assura41 ELW, VLW resize: CPU load 101%
  • Subscribers 133
  • Views 15231
LayMan
LayMan over 14 years ago
****************************** The problem was happen after checked DRC. **********************************
The Error Layer Window and VLW keep resize. The user's CPU load on share server is 101%.
Program: @(#)$CDS: virtuoso version 6.1.3 05/19/2010 01:23 (cic612lnx) $
Sub version: sub-version IC6.1.3.500.19 (32-bit addresses)
Operating system: Linux 2.6.39-hardened-r8
IBM_PDK cmrf7sf skill procedures for Cadence 6.1 - Sep 30 16:22:02 2011
\w *WARNING* No user triggers registered for viewType schematicSymbol.
\w *WARNING* No user triggers registered for viewType maskLayoutXL.
Load shared object file /opt/soft/Cadence/ASSURA41/tools.lnx86/assura/lib/libavview.so
    : libavview.so version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/09 14:47 (sfrh259)
******************************    The problem is happen after try to open ELW after DRC check.  **********************************
cmd is /opt/soft/Cadence/ASSURA41/tools/assura/bin/assura ..../ibm_ic/DRC/OSC.rsf -cdslib .../ibm_ic/cds.lib -libdefs .../ibm_ic/lib.defs -restart -gui
\o Starting the Assura DRC Run: IPC Id ipc:2: pid 22223.
\a leSetLSWBBox(list(0:257 160:1024))
\r t
\r t
\r t
\r t
\a hiiSetCurrentForm('tmp6)
\r t
\r t
\r t
\a vuiTailFile( "/egr/research/RFIC/sanghlao/ibm_ic/DRC/OSC.log" )
\o Tailing "/egr/research/RFIC/sanghlao/ibm_ic/DRC/OSC.log"
\r window:7
\r t
\r t
\r t
\a hiiSetCurrentForm('vuiDRCForm)
\r t
\r t
\r t
\r t
\p >
\r t
\r t
\r t
\a hiDBoxOK(vuiDBox)
\r t
\o Checking out license for "Assura_UI" 4.10
\r t
\a vuiELWResize(list(1016:-520 1846:-320))
\r t
\a vuiResizeLW(list(816:440 2096:1402))
\w X Toolkit Warning:
\w Name: scrollBarH
\w Class: XmScrollBar
\w The scrollbar increment is less than 1.
\w
\w Name: scrollBarH
\w The scrollbar page increment is less than 1.
\w
\r t
\r t
\r t
\r t
\r t
\w Name: scrollBarH
\w
\w Name: scrollBarH
\w
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
\r t
  • Quek
    Quek over 14 years ago
    Hi LayMan
    It is a little hard to know what is causing so I think the best approach is to try the latest version of Assura to see if it still happens. : )
    Best regards
    Quek
  • LayMan
    Thanks Quek,
    It is working on other system,  Ubuntu Natty.
    Best regards
    LayMan
