  3. How to do a sp simulation using the netlist created by relxpert...
  • Subscribers 132
  • Views 14884
How to do a sp simulation using the netlist created by relxpert?
wyliechee
wyliechee over 14 years ago
Hi all,
After running the relxpert, I would like to run an sp simulation with OCEAN script. However, after adding the commands in the script, the result still contains only the tran simulation which is specified by relxpert by default. Wonder if I need to modify the netlist to get it successful?
    Aging simulation only really works with transient. You should contact customer support if you want to do this - maybe something can be enhanced to allow this.
  • wyliechee
    Andrew:
    Thank you for your reply. However, I assume after the relxpert simulation, by when we got the *Age.p2 aged netlist, we can do some other simulation on it except for the transient.Am I right?
    I don't think it's possible right now. Please check with customer support (I don't have time to experiment right now myself).
    Kind Regards,
