  3. How to debug VerilogA compilation when code seems to check...
  • Subscribers 132
  • Views 17235
How to debug VerilogA compilation when code seems to check clean but simulation aborts when compiling ?
Herge
Herge over 14 years ago
Hello I have a verilogA module using multi-terminal ports and where I want to use for loops to assign all currents. I took care to use genvars, and I don't get any syntax error during the check after saving the verilogA view. However during simulation, spectre is aborting (very laconically, even if I use option +debug).
** Below the header of my module :
  module qnrmesh2d(majport,minport);
   // Majority carriers terminals
   inout [1:`QNRMESH2D_NPORTS] majport;
   electrical [1:`QNRMESH2D_NPORTS] majport;
   // Minority carriers terminals
   inout [1:`QNRMESH2D_NPORTS] minport;
   electrical [1:`QNRMESH2D_NPORTS] minport;
**  Below the declarations of my genvars :
    genvar    thisPort, otherPort, refPort;
**  Below a typical set of loops
     // Trick to define the reference port
      for (refPort = `QNRMESH2D_NPORTS; refPort == `QNRMESH2D_NPORTS; refPort = refPort + 1) begin
          // Generate the charge balance equations at all ports
          for (thisPort = 1; thisPort < `QNRMESH2D_NPORTS; thisPort = thisPort + 1) begin
              // Extract the quasi-Fermi potential and evaluate its exponential
              Imref_min[thisPort] = sq_min*V(minport[thisPort],majport[thisPort]);
              LimExpImref = limexp(Imref_min[thisPort]/$vt);
              // Loop over all ports to compute the current in the selected port (thisPort)
             for (otherPort = 1; otherPort < `QNRMESH2D_NPORTS; otherPort = otherPort + 1) begin
                  // Assign the drift majority current
                 I(majport[thisPort],majport[refPort]) <+ Gdrift_maj[`index2D(`QNRMESH2D_NPORTS,thisPort,otherPort)]
        *V(majport[otherPort],majport[refPort]);
             end
       end
end
** ICFB message when saving :
          veriloga Diagnostics: Warnings exist in veriloga text of cell qnrmesh2d.
          Abort
 ** Spectre.out contains nothing beyond the lines "Loading ..lib...so"
    It sounds as if spectre is aborting both during the check (hence the Abort message) and also during simulation. In order to check this, we'd need to know which spectre version you're using (the subversion should show in the spectre output log file), and also the full Verilog-A model.
    If you can't post that here, please contact Customer Support.
  • Herge
     Andrew,
     The spectre version is : 10.1.1.092.isr7 32bit -- 22 Apr 2011.
     For the complete code I'll go via the support line.
  • Herge
    See support request nbr : 42907042 (it has the complete files attached).
