  3. How to translate netlist with subcircuits into top-level...
  • Subscribers 131
  • Views 6882
How to translate netlist with subcircuits into top-level subcircuit?
TiNat
TiNat over 14 years ago
Hello. Who know, is it possible in Cadence translate netlist with subcircuits into
top-level subcircuit. I extract netlist with parasitics using Calibre. It creates
three files. But I can't simulate such netlist in SignalStorm. I don't want to edit
file manualy because it large and I want get single spice netlist.
Best Regards.
  • skillUser
    skillUser over 14 years ago
    Unless I am misunderstanding your question, you are asking if it is possible to create a flat CDL (or Spice?) netlist.  Take a look at Solution 11030558 to see if it helps you.  Not sure if the link will work, I tried to insert it but it is not displaying correctly, here it is: http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11030558
    If this does not help you will need to give more details (what Cadence version? what netlist format etc.)
    Lawrence.
