  3. APS, Multi-threading, High-Performance Simulation...
  • Replies 11
  • Subscribers 131
  • Views 31863
aditeman
aditeman over 13 years ago
Andrew,
I am a bit confused with all of the high performance simulation options in ADE-XL/GXL.
I am using IC 6.1.5.506 with  MMSIM 10.11.200
On ADE I have:
  1. "Options->Job Setup->Max Jobs"
   2.  "Options->Run Options-> Run In"
  3.  "High-Performance Simulation->Mode, Multithreading options, Affinity"
  4. "Options->Analog->Multithreading Options"
Maybe others...
What is the up to date way to run my simulations as fast as possible?
The main reason I'm asking is that I've had some problems when setting things such as APS + Max Jobs=8. For example, I've had these settings and sent a small simulation with a few corners and after waiting 10 minutes it still hadn't started. In general, it seems to take minutes until simulations start running sometimes (and then they run very fast).
Any suggestions/explanations?
ADi
  • aditeman
    Can anyone help me on this?
    Adi
  • tkhan
    tkhan over 13 years ago
    Are you running in local or distributed mode? Do you have enough licenses available?
  • aditeman
    I can run in either local or distributed, and I have plenty of licenses, as I am a student in an academic institute and we get an enlarged package, so I don't mind using a lot of licenses.
    This controls the number of parallel simulations that may be run at once in ADE XL. If you are using multiple tests in ADE XL, or corners, or sweeping variables or parameters, each one of these counts as a "job", and they can be run in parallel (on the local machine, on a remote machine, or distributed using a queueing system). Also if using Monte Carlo, it can break up the number of monte carlo points into chunks, based on the number of available parallel runs.
    This is not that useful - it's more to do if you hit the "Run" button again before existing jobs have finished - maybe having changed some setup.
    This allows an individual simulation job to take advantage of multi-core technology and do things like the matrix solve in parallel - so it can speed up an individual simulation. Processor Affinity should be left alone (it allows you to get absolutely the best performance by telling the simulator which CPUs in a multi-core machine are to be used, but this is only ever useful if you have complete control over the machine you're running on, and has to be set carefully and is not normally worth the bother of setting)
    This is pretty much obsolete nowadays - it was an earlier form of (limited) multithreadhing. It controls the same thing that's on the High Performance Options setting now - but that's the preferred location (the high performance options) to set multi-threadhing.
  • aditeman
    Thanks!
    Do you have any idea what could be causing a long delay to initiate simulations? In other words, I press the "run" button, and once in a while I can wait a minute or longer (sometimes I stop it out of frusteration) before the simulations actually start. I have, for example, waited over 10 minutes for a simple simulation to start, then changed servers, and had the whole simulation from start to finish take 20 seconds. Our system administrator has tried to look into it, but as it happens quite sporadically, we have no clue what could be causing it. I do have a feeling, though, that it mainly happens when I try to run on multiple CPUs...
    Thanks again,
    Adi
  • Rob Gregoire
    Rob Gregoire over 13 years ago
     Hi Andrew and others,
    I am running a long sim for a delta-sigma converter. Is there an optimum number of threads to use? I have six processors available, but I seem to remember that someone saying that at some point the speed increase is minimal if you add more processors -- I just don't remember what that point of diminishing returns was.
    Best regards,
    Rob
    Rob,
    It's quite hard to be precise about this - APS supports up to 32 cores these days - and I have customers using that number (for very large circuits - e.g. several million transistors and even larger numbers of parasitics), so your mileage may vary. Generally speaking it's bigger circuits that will benefit from more threads. Doing some quick experiments with different number of threads would allow you to assess this for your size of design. You can check the utilization figures too that are reported in the log file (bearing in mind that you really wouldn't expect it to be able to fully utiliize all threads anyway).
  • Rob Gregoire
    Andrew, thanks for the answer. As always, I'm am very appreciative of the time you spend here helping.
  • lartola
    lartola over 8 years ago
    Andrew,
    do you know if multithread works for Cadence 5.1.41 ?
    Thanks in advance for your time
    Laurent
    Laurent,
    Provided you're using spectre from an MMSIM version later than (say) MMSIM71 (although that's pretty old - I suggest you use a release newer than 7-8 years old when  you have MMSIM72, MMSIM101, MMSIM111, MMSIM121, MMSIM131, MMSIM141, MMSIM151 and SPECTRE161 to choose from). If you do that, and are also using a later subversion of IC5141, then ADE will have a Setup->High-Performance Simulation form. If you enable APS, you have the choice of multi-threading.
    Certainly you should not use the spectre that came with IC5141, because that hasn't really been touched (other than a few bug fixes here and there) since 2004.
