  3. DC Match Over Corners
  • Subscribers 132
  • Views 14782
BVT1
BVT1 over 14 years ago
I am using ADE 5.10.41 to run 80 DC match corner simulations but can't seem to get the mismatch summary for all corners in one table that I can hopefully import to Excel.
I tried the results browser but the Select Data menu is grayed out, so when I select the totalOutput directory under dcmatch I only get the variation of one corner.
I then tried using Print > Mismatch Summary under the Results menu in ADE, and even though I can see the corners defined in the end as parametric variables, I can't select them all.
I can tabulate the results as long as I can get an expression for the total output variation of the DC match analysis in the calculator, but didn't have any luck with that either.
 Any ideas?
Thank you
