  3. Writing simulation data into a file after running
  • Subscribers 132
  • Views 14858
Medya
Medya over 14 years ago
Hi, I use oceanscript for running a long time simulation, but after hours when simulation completed this error occurred>>cannot open output file ./paramoutput.txt<< before this long time running, I test the script and it works well.my q here: is that any way to rewriting the simulation result into file without  running the simulation a gain. I am beginner in ocean,use simple code!!
some of my scripts:
analysis('tran ?stop "150n" ?errpreset "conservative" ?maxstep "0.01n" )
desVar( "R" 10k )
desVar( "delta3" .1 )
desVar( "delta2" .1 )
desVar( "delta1" .1 )
desVar( "a" 500m )
paramAnalysis("a" ?start -500m ?stop 500m ?step 100u)
paramRun()
temp( 27 )
value = value((VT("/net19") - VT("/net15")) 9.995e-08)
ocnPrint(?output "./paramOutput.txt" ?precision 10 ?numberNotation 'scientific ?width 20 value)
Thanks.
Medya
    Instead of re-running the simulation, you can use openResults("/path/to/the/results/psf") (i.e. don't do the bits up to and including the paramRun()), and then you'll be able to do the statements afterwards.
