  3. ADE XL: default x axis for plots
  • Subscribers 132
  • Views 15740
keble6
keble6 over 14 years ago
 I typically use ADEXL in "sweeps" mode, using corners for PVT and a Global Variable for some parameter such as a trim value - which seems to be called a design point in ADE XL.
When I come to plot, using Plot All (which plots results from both corners and  "design points") the default axis is NOT the design point variable, but a variable which is part of my corner set up.
This is not only illogical (to me anyway) it is irritating, as I always have to chnage the x axis variable.
Could the default axis variable be changed in future - or at least made programmable?
    I believe this is on the list of things to do - but please log a service request to ensure your requirements are captured.
  • keble6
     Thanks - I have just done that
