  3. Transient Analysis: tran_info and finalTimeOP
  • Subscribers 132
  • Views 14997
BVT1
BVT1 over 14 years ago
I am using ADE 5.10.41 to simulate a circuit for which I want to obtain the OP at 10μs. There are two obvious ways to do this in transient analysis; I can either check the Save Final Op Pt  and run a 10μs simulation or add 10μ in the infotimes field in the options menu. Both of these work just fine through the GUI. I can eaisly extract a scalar, for example, for the VDS of a device using the info OP measurement in the calculator.
When I try to perfrom the same simulation(s) using Ocean, I don't seem to be able to extract any OP results. In the case of final time OP, I use selectResults('finalTimeOP) but Ocean returns: Results finalTimeOP are not available for "/local_path/design/spectre/schematic". However, the results are there since the finalTimeOP.info is generated in the above path. In the case of Info Times, I use selectResults('tran_info) but the result I get is, what I believe, an ID code for the specific OP measumernt I perform and looks like this: drwave:175845424.
Is there anyway to extract OP results from a transient analysis using Ocean?
Thank you
