  3. automatic insertion of E2R and R2E connect modules
  • Subscribers 133
  • Views 17565
freitas
freitas over 14 years ago
I'm trying to run a very trivial example to see how the automatic insertion of E2R and R2E connect modules works. Please find the code below. Unfortunately, I get the following elaboration error:Elaborating the design hierarchy: Top level design units: top
Discipline resolution Pass...
ncelab: *E,CUVDRF: Could not determine discipline for top.xr.
Would I be missing some elaboration option?
thanks,
`include "constants.vams"
`include "disciplines.vams"
module top;
wreal r, xr, wr;
assign xr = 3.14;
ams_electrical_src e_s1(r);
// causes insertion of Electrical2Real
// connection module
  ams_electrical_dst e_d1(xr);
// Real2Electrical connection module
  ams_wreal_src w_s1(wr);
// Coercion of SystemVerilog real variable
// to wreal
endmodule
module ams_electrical_dst(e);
   input e;
   electrical e;
  initial #10 $display("%M: %f", V(e));
endmodule
module ams_electrical_src(e);
  output e; electrical e;
   analog V(e) <+ 5.0;
endmodule
module ams_wreal_src(w);
     output w; wreal w;
     assign w = 2.5;
endmodule
    I could run your example by creating forum.f (the code was in forum.vams):
     forum.vams
    -reflib $AMSHOME/tools/affirma_ams/etc/connect_lib/connectLib
    -discipline logic
    -amsconnrules CR_full_fast
    -timescale 1ns/1ps
    -ieinfo ieinfo.txt
    run.scs
    where run.scs contained:
    tran tran stop=1u
    and then I did:
    irun -f forum.f
    or if I wanted to see things in simvision:
    irun -f forum.f -access +rw -gui
    Note it's the -discipline logic which was the key. You didn't say how you were running the simulation, so I guessed...
  • freitas
    It works on my end!
    I didn't know the "ieinfo" option either! Cool!
    Thanks Andrew!
