  3. ADE XL doesn't run
  • Replies 21
  • Views 13217
ADE XL doesn't run
navi2582
navi2582 over 14 years ago
I have looked at some previous posts and wanted to do the same, but
when I tried to execute,
$ldd Cadence/IC615/tools/dfII/bin/Xndx
I get a message,
ldd: Cadence/IC615/tools/dfII/bin/Xndx: No such file or directory
Is there any chance that this might be the reason for ADE XL to not run?
Or could anyone please point to reasons why it is not running?
Navi
  • navi2582
    Andrew,
    I see this in the log file,
    /CADENCE/IC.6.15.509/tools.lnx86/bin/cdsXvncd: /lib/libgcc_s.so.1: version `GCC_4.2.0' not found (required by /CADENCE/IC.6.15.509/tools.lnx86/lib/libstdc++.so.6)
    What OS (distribution and version) are you using?
  • navi2582
    when I run the "/IC.6.15.509/tools/bin/checkSysConf   IC6.1.5", I got this:
    Date information gathered: Tue May 22 17:05:48 PDT 2012
    Host Name ..............:  xxxxx
    Hostid .................:  xxxxxxxx
    Operating System .......:  Linux / x86_64
    OS Version .............:  4.0
    Kernel Version .........:  2.6.9-5.ELsmp
    Hardware Type ..........:  x86_64
    Memory .................:  16030 Megabyte
    No. of CPUs ............:  8
    Total Swap Space........:  2047 Megabyte
    X Server ...............:  X Window System Version 6.8.1
    Patch Data file ........:  /tools/CADENCE/IC.6.15.509/share/patchData/Linux/x86_64/redhat/4.0WS/IC6.1.5
    ****************   Now verifying configuration     ****************
    Validating Kernel requirements...
                Minimum       Installed         Status  Info
                2.6.9-89.0.19.EL2.6.9-5.ELsmp     FAIL    Wrong kernel version installed
    Validating MEMORY requirements MegaByte ...
                256MB     16030MB   PASS
    Validating SWAP requirements in MegaByte ...
                512MB     2047MB    PASS
    Validating DISPLAY requirements...
                24 planes     ---            PASS
                PseudoColor
    Validating PACKAGE requirements.....8 to check
    #   PACKAGE          Release    Build          Installed       Status  Info
    1   glibc            2.3.4      2.41           2.3.4-2.36      FAIL    Old build version
    ->                                                              installed.
    ->  'GlibC'
    2   pdksh            5.2.14     30.6           5.2.14-30       FAIL    Old build version
    ->                                                              installed.
    ->  'Ksh'
    3   elfutils         0.97       1-5            0.97-5          PASS
    ->  'Elfutils Package'
    4   elfutils-libelf  0.97       1-5            0.97-5          PASS
    ->  'Libelf Library'
    5   xorg-x11-Mesa-libGL6.8.2      1.EL.52        6.8.1-23.EL     FAIL    Old release version
    ->                                                              installed.
    ->  'Mesa Package'
    6   gdbm             1.8.0      24             1.8.0-24        PASS
    ->  'libgdbm.so.2'
    7   readline         4.3        13             4.3-13          PASS
    ->  'Readline lib'
    8   glibc-devel      2.3.4      2.41           2.3.4-2         FAIL    Old build version
    ->                                                              installed.
    ->  'GlibC-devel'
    Validating FILE existence .....0 to check
    Validating NOTFILE existence .....0 to check
    Configuration checks failed on this workstation (xxxxx), status is: FAIL
    So I have asked our IT admin to install the latest patches (found on cadence website) ,
    kernel-2.6.9-89.0.19.EL
    glibc-2.3.4-2.41
    pdksh-5.2.14-30.6
    elfutils-0.97.1-5
    elfutils-libelf-0.97.1-5
    xorg-x11-Mesa-libGLU-6.8.2-1.EL.52
     Thanks Andrew for the help!!!
    Navi
  • navi2582
    oopsie..will not repeat it!!
  • habet
    habet over 13 years ago
    Hello navi,
    I want to know if you solved your problem with ADE xl.
    I have same problem, i can simulate with ADE but ADE xl doesn't work ?
    wich design kit and OS are you using ?
    best regards
    abdel
    Abdel,
    More usefully, can you say which version you are using, and which OS you are using?
  • habet
    Andrew,
    I am using virtuoso IC6.1.5-64b.500.9  (64-bit addresses) and linux on fedora 14.
    Here is some informations from CDS.log :
    \o Program:        @(#)$CDS: virtuoso version 6.1.5-64b 01/16/2012 22:41 (sjfdl051) $
    \o Hierarchy:        /logiciels/Cadence/IC615/tools.lnx86/dfII/
    \o Sub version:        sub-version  IC6.1.5-64b.500.9  (64-bit addresses)
    \# Host name (type):    xxxxxx
    \# Operating system:    Linux 2.6.35.14-103.fc14.x86_64 #1 SMP Thu Oct 27 15:41:25 UTC 2011
    \# Memory report:    maximum data size 274877906943 (0x3fffffffff) bytes
    \# Memory report:    maximum process size 18446744073709551615 (0xffffffffffffffff) bytes
    \# Initial sbrk value:    278859776 (0x109f1000) bytes
    \# Available memory:    40187300 (0x26535a4) kilobytes
    \# System memory:    49306804 (0x2f05cb4) kilobytes
    \# Maximum memory size:    50490167296 (0xbc172d000) bytes
    \# Max mem available:    41199403008 (0x997ad0000) bytes
    \# Initial memory used:    47607808 (0x2d67000) bytes
    Best regards
    Abdem
    I'd advise you to contact customer support. Make sure that "virtuoso -nograph" runs OK too.
  • navi2582
    navi2582 over 13 years ago
    Hi Abdel,
    I was able to figure out how to run the ADE XL (but it's not the ideal solution). Since you are using the same version of virtuoso, it might work for you as well.
    Create a new directory with "cds.lib" and launch virtuoso (as shown below).
    Ex:
    -->cadence (current working directory)
         -->cds.lib
         --> other files
     to
         -->cds.lib
         --> other files
     -->cadence_new (new working directory)
          -->cds.lib (INCLUDE ../cadence/cds.lib) --> try launching virtuoso from here.
    Hope this helps!!
    Navi
  • IC616
    IC616 over 12 years ago
     customer support
