  3. ADE XL doesn't run
  • Replies 21
  • Views 13209
ADE XL doesn't run
navi2582
navi2582 over 14 years ago
I have looked at some previous posts and wanted to do the same, but
when I tried to execute,
$ldd Cadence/IC615/tools/dfII/bin/Xndx
I get a message,
ldd: Cadence/IC615/tools/dfII/bin/Xndx: No such file or directory
Is there any chance that this might be the reason for ADE XL to not run?
Or could anyone please point to reasons why it is not running?
Navi
    Which version are you using (type "virtuoso -W" at the UNIX prompt)? If you run "virtuoso -nograph" does that work? (Type exit at the prompt if it does in order to exit the non-graphical invocation).
  • navi2582
    Thanks Andrew.
    it is,
    sub-version IC6.1.5-64b.500.9
     I also tried virtuoso -32, but it didn't work. I will try your suggestion early tomorrow and will get back to you.
  • navi2582
     Andrew,
     when I do the "virtuoso -nograph", it does not even launch the virtuoso window. Do you have any suggestions?
    Navi
  • navi2582
     ohh wait..I see something.
    *WARNING* Unable to open -nograph X Window Display "<hostname>:80"
    *WARNING* (using "exec /CADENCE/IC.6.15.509/tools.lnx86/dfII/../bin/cdsVncserver :80&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/<hostname>:80.log
    *WARNING* Trying another display.
    what can we infer from this?
    Navi
    Navi,
    It's not supposed to launch the Virtuoso window. That's the point... it's a "non-graphical" mode for Virtuoso, and this is what is being used for the background process. If you type "virtuoso -nograph" in a UNIX terminal, you should see:
     COPYRIGHT © 1992-2012  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
              © 1992-2012  UNIX SYSTEMS Laboratories INC.,
                             Reproduced with permission.
    This Cadence Design Systems program and online documentation are
    proprietary/confidential information and may be disclosed/used only
    as authorized in a license agreement controlling such use and disclosure.
              RESTRICTED RIGHTS NOTICE (SHORT FORM)
    Use/reproduction/disclosure is subject to restriction
    set forth at FAR 1252.227-19 or its equivalent.
    Loading geView.cxt
    Loading menuBuilder.cxt
    Loading schView.cxt
    Loading selectSv.cxt
    Loading LVS.cxt
    Loading layerProc.cxt
    Loading xlUI.cxt
    Loading auCore.cxt
    Loading vhdl.cxt
    Loading seismic.cxt
    Loading ci.cxt
    Loading ams.cxt
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
    And the last line is a prompt, at which you can type SKILL command (e.g. exit() to exit the virtuoso nograph session).
    Did it do that?
    Probably your best bet is to go to customer support as otherwise debugging via the forum could be tricky!
    Did you look at the cdsXvnc output log to see if that said anything?
    You might want to try experimenting with the environment variables CDS_XVNC_TENBASE and CDS_XVNC_OFFSET (search in cdnshelp for details on these). These allow alteration of the display range used.
  • navi2582
    I already opened a Service Request (#42922780) for this issue. I just wanted to take others opinion too so that it will faster to debug the problem. Initially I thought there was a problem with Monte Carlo simulation but later realised that I could not even run a simple simulation in ADE XL, which ADE L was able to run.
  • navi2582
     two questions,
    1) where can I find the cdsXvnc ouput log?
    2) when executed "echo $CDS_XVNC_TENBASE" and  "echo $CDS_XVNC_OFFSET", both resulted in Undefined variable. Are those already set or do I need to set?
     Please let me know.
    Thanks.
    It told you in the message you posted where to find them...
    And those vars would not be set by default. Setting them overrides the defaults (see the manual for more details).
  • Tawna
    Tawna over 14 years ago
    Hi Navi,
    Please be mindful and do not open Service Requests (SRs) with Customer Support  _and_ report the same issue on the forums.  A  majority of posts are answered by AEs  (often on our own time) and it tends to stretch our extremely limited bandwidth...   Plus, when AEs see people “double dipping” (asking the same question across multiple forums), they are less likely to answer their question.
    In summary…post questions on the forums….or file a Service Request….but not on both.   Thanks for your consideration!  J
    Best regards,
    Tawna
