  3. Extracted-View simulation fails with 6.1.5 but not with...
  • Subscribers 132
  • Views 15457
Extracted-View simulation fails with 6.1.5 but not with 6.1.4
baenischfau
baenischfau over 14 years ago
Hi all,
I'm currently during final phase of pre-tapeout characterisiation of small VCO, which I designed
with 6.1.5.72b using the S35 technology of AMS. Up to now everything went quite smooth, including
QRC-Extraction. Last week I added a output driver with some different resistors (rpoly2) from the PDK
and  now I can't get my simulations to work with 6.1.5, the spectre version seems to have no influence.
First of I all I get model subcircuits within my av_extracted netlist which I did not specifiy in the Netlist-Section
of QRC-Setup. This model definition includes two definitions that cause the simulation to fail in 6.1.5 but work fine
with 6.1.4. The model entry:
subckt rpolyhc PLUS MINUS REF
parameters _par0=10u l=10u mult=....
R1 (PLUS net9) rpolyh w=_par0 l=....
CS0 (PLUS REF) capacitor c=..
CM (net9 REF) capacitor c=(...tanh(l/2"w"))r("w)))*cap) m=mult
ends rpolyhc
The simulator seems to stop during netlist parsing, and bails out with two errors at the CM line.
ERROR (SFE-874): "input.scs" 25: Unexpected quoted string ""w". Expected close parenthesis or comma
ERROR  (SFE-709): "input.scs" 25: No master specified for instance `cap'.
Is there any fast and simple way to get 6.1.5 to accept this netlist, like 6.1.4 does ? Main Reason is, that 6.1.4
does not support a lot of my measurements, also the waveform viewer of 6.1.5 is way better (still not perfect)
compared to 6.1.4. Another important point is that our QRC (10.13) version seems to dislike 6.1.4, so I have to
permanently switch between the versions if I change anything ...
Best Regards
Andi
    You should contact customer support - it's not a matter of the simulator accepting this netlist - the netlist is wrong (which might be a PDK issue) - but we'll need to see the data - virtually impossible to debug with edited versions of the netlist.
