  3. ADEXL Monte Carlo Simulation Error: no statistical data...
  • Subscribers 132
  • Views 17909
ADEXL Monte Carlo Simulation Error: no statistical data generated for the test
ranran
ranran over 14 years ago
Hey all, I am encountering a problem when running Monte Carlo simulation in ADE XL. I want to use Monte Carlo mismatch simulation to find out the achievable IIP2 of a passive mixer at each corner (typical fast and slow). I am using virtuoso 6.1.4 and IBM cms9flp design kit. At the end of the running it gives the warning as follows:
ADEXL-5052: Monte Carlo run stopped because no statistical data generated for the test: XXX
1. In the output setup, I did add a scalar expression of IIP2, but it is a little bit complicated because my in/output signal is current. I have IIP2=ipn(hb2dBm hb1dBm 2 1), where I substitutehb2dBm and hb1dBm with dBm version of hb1 and hb2 where
hb1=harmonic(i("/V14/PLUS" ?result "sweephb_hb_fi-sweep") list(-1 0 1)) ---- fund
and hb2=harmonic(i("/V14/PLUS" ?result "sweephb_hb_fi-sweep") list(0 -1 1)) ---- 2nd order harmonic
2. For the corner setup, I turned off the process variation switch, customized the model file of design.scs for each corner and included them in the corner setup window. I also chose method "All" for Monte Carlo setup.
I am guessing the problem comes from step 1 with the expression for IIP2, but I dont know exactly where because it worked well for single simulation in ADE L.. and it is a scalar. Anyone has experience on this? Any help will be really appreciated
    Change the ?result bit to ?result "hb_fi" rather than ?result "sweephb_hb_fi-sweep". In IC615 ISR3 onwards, the results browser produces expressions using the "aliased" names for results, which then work properly in Monte Carlo.
    In general I'd advise using IC615 (recent hotfix) if you can as there have been a lot of improvements.
