  3. LVS run with linux command
  • Subscribers 132
  • Views 17154
narendra046
narendra046 over 14 years ago
 Hi friends,
             I want to run lvs with command line. For running DRC, I have created .rsf file as a input which conatins all the inforamtion about the rule files, cell inforamtion ...etc. Then, I have a command in terminal:     assura *.rsf            >>>> its working...
Like this, how to run assura LVS........
Narendra
  • kamit
    kamit over 14 years ago
    Running LVS is no different.
    Just execute assura *.rsf again. Incase you have any confusion in rsf creation for LVS, you can get rsf for LVS run by one time GUI execution and use it for command line.
  • narendra046
    Hi Kamit,
              Thanks for your response........
    I have genarated *.rsf file from  assura lvs window. This is like...........
    avParameters(
     ?inputLayout ( "df2" "nan_fpk" )
     ?cellName "bias_ft"
     ?viewName "layout"
     ?runName "kkk"
     ?workingDirectory "./lvs"
     ?technology "assura_1830HJK"
     ?techLib "./assura_tech.lib"
     ?techRuleSet "LVS_4M_Thick_TOP"
     ?set ("TOP_THICK_METAL" "USE_1830HJK")
     ?avrpt t
     ?flattenCellContents ("*")
    When I was running this, It showing.. errors exist in *.rsf file.
    Please let me know if any other information included in this *.rsf file.........
    Narendra
  • kamit
    This snippet of RSF is not complete as I can't see rules and schematic information in this.
    Did you actually run LVS through GUI and was it a successful run?
