  3. Regarding the tie down diode
  • Subscribers 133
  • Views 17950
PeterXia
PeterXia over 14 years ago
Process: IBM analog/RF 130 nm.
Hi all, tie down diodes are used to prevent gate damage during fabrication.
For nMOS, it is clear that we can tie n+/sub diode to the gate, as a reverse biased diode.
However, there is a pcell called pTiedown. It is p+ diffusion in n-well. What it is for?
  • Quek
    Quek over 14 years ago
    Hi Peter
    The answer is in this designer's forum post. Would you happen to be "peterki" too? : )
    Best regards
    Quek
  • peterki
    peterki over 14 years ago
    Hi Quek, Thank you so much for answering my question, as well as my other post. The answer to this post can be found at http://www.designers-guide.org/Forum/YaBB.pl?num=1338412194
