  3. Looking for a dbCreateLine bindkey for Virtuoso 6.1
  • Subscribers 132
  • Views 14982
LongTimeNovice
LongTimeNovice over 14 years ago
Hello.
In Virtuoso 5.1, I had a bindkey that looked like this:
"<Key>y"            "CreateLine()")
You'd hit "y" and then click a point and then another point, and it would draw a 0-width line between the two points.
 Virtuoso 6.1 has the command dbCreateLine, but I haven't been able to create a bindkey for it, and I also haven't found it in my menus and toolbars.  Is there a way to create a bindkey for this, and does the command exist in a menu or toolbar within Virtuoso?
 Thank you!
Steven.
    Steven,
    CreateLine() was presumably a custom function defined in your environment (it's not a Cadence function), which probably used an enter function (e.g. enterPoints() or enterLine() to digitize the points, and then called dbCreateLine() when it was done). The same underlying functions still exist, so presumably you could use the same custom code in IC61 too.
    There's no menu to digitize a zero-width line (nor was there in IC51) in the layout editor.
  • LongTimeNovice
     Thank you, Andrew!
     I'll contact my loal CAD group and ask them to recreate that custom function for 6.1.  Thank you for your help!
     Steven.
