  3. Verilog-a function local variables Visualization & Anal...
  • Subscribers 132
  • Views 2691
Verilog-a function local variables Visualization & Analysis
soathana
soathana over 14 years ago
Is there a nice way to expose function variables to Visualization & analysis XL?
Variables at model level can be saved with  saveahdlvars option and accesible through signal browser, but not the same applies for analog function variables inside the model. Since there are a lot of them i cannot return them as a means of function return. Any ideas?
Sotiris
    Sotiris,
    I think this would need an enhancement to the simulator (I've not tried, but am not aware of an option). Please contact customer support.
  • soathana
    Andrew thanks for your response. The only way around it so far is to model independently in another software (like Matlab for example) the  given functions and check the variables there. Fortunately V&A gives you the option to export whole signal values to csv files which are really easy to manipulate.
    Cheers,
    Sotiris
     Sotiris,
    Another approach would be to simulate the model in AMS Designer, and then you can debug the model using simVision (you need to ensure that it gets simulated as Verilog-AMS though - there's a switch for that when using the OSS/irun flow).
  • soathana
    Andrew, What I did was open the circuit from AMS hierarchy editor, and simulate in AMS environment using Simvision you mentioned. The problem is that even though i can see the parameters now in simvision environment, they have a No Read Access in value. I enabled in access options, access visibility = all (in AMS options -> Miscellaneous) but still no luck with it. Any ideas? Thanks, Sotiris
