  3. Changing simulation results destination file from ADE W...
  • Subscribers 132
  • Views 15235
Changing simulation results destination file from ADE Window
JustinTaylor86
JustinTaylor86 over 14 years ago
Is there a way to change the destination file of results from the ADE window?
I know this can of course be done by running ocn scripts instead of running simulations through the ADE but in this case I do not want to run scripts.
    What do you mean by "change the destination file of results..."?
    I don't understand the question.
  • JustinTaylor86
    The default is say something/spectre/schematic for the results
    Say I wanted to change the file to something/spectre/schematic1 how can I do this?
    The default is based on the view name you're simulating. Once the simulation has completed, you can save the results to a different name, using Results->Save.
    You can also get it to automatically save results after each run - using:
    envSetVal("asimenv.misc" "numberOfSavedRuns" 'int 5)
    for example (the default is 0).
    But you can't change the default location - that will always be based on the view name.
