  3. Error when launch icfb in CentOS
  • Views 17583
ycau
ycau over 14 years ago
 Hello all,
The OS info is following:
  uname -a
Linux odemo 2.6.32-220.17.1.el6.i686 #1 SMP Tue May 15 22:09:39 BST 2012 i686 i686 i386 GNU/Linux
icfb version is IC5141.USR5.hotfix
 After launch icfb, I got the following error:
 X Error of failed request:  BadName (named color or font does not exist)
  Major opcode of failed request:  45 (X_OpenFont)
  Serial number of failed request:  15
  Current serial number in output stream:  30
Please let me know if anyone has a solution.
Thanks a lot in advance
--ycai
  • navi2582
    navi2582 over 14 years ago
    Cadence doesn't support CentOS.
  • ycau
     I understant this.
    I run virtuoso on the same computer, everything is fine.
    But some old database needs icfb, I just wonder if anyone happen to
    use icfb on CentOS has met and solved the above error.
  • skillUser
    skillUser over 14 years ago
    Take a look at Solution 11030516, in short try using the -nosplash command line argument, it should resolve the issue.
    Lawrence.
  • ycau
     Great, this solves the problem.
    Thank you for the help, Lawrence!
