  3. Assura 3.1.4 LVS failure
  • Subscribers 133
  • Views 16086
stefanobre
stefanobre over 14 years ago
I'm facing a problem with assura 3.1.4 in the LVS. Independentely on the kind of circuit i run, the DRC works according to the design rules of my technology, while the LVS systematically fails with this error message (example of a simple inverter   postimage.org/.../ ):
  Loading umc13mmrf/libInitCustomExit.il ... done!
Loaded umc13mmrf/libInit.il successfully!
*WARNING* Cannot find /cadence/ASSURA/tools.lnx86/dfII/etc/tools/layoutXL directory to load environment variables
Compiling rules...
 Assura LVS of UMC 0.13um Mixed-Mode and RFCMOS 1P8M MMC FSG Enhancement Process (Ps: Pls select the switches of metal opton and metal combination !! )
error:  Unknown input 'incremental' found in this geomConnect() command.
   629. geomConnect(incremental (buttOrOver ME2 MESH_SY_P1_CONN) (buttOrOver ME3 MESH_SY_P1_CONN) (buttOrOver ME2 MESH_SY_M1_CONN) (buttOrOver ME3 MESH_SY_M1_CONN) (buttOrOver ME2 MESH_SY_P2_CONN) (buttOrOver ME3 MESH_SY_P2_CONN) (buttOrOver ME2 MESH_SY_M2_CONN) (buttOrOver ME3 MESH_SY_M2_CONN) (buttOrOver ME2 MESH_ASY_P1_CONN) (buttOrOver ME3 MESH_ASY_P1_CONN) (buttOrOver ME2 MESH_ASY_M1_CONN) (buttOrOver ME3 MESH_ASY_M1_CONN) (buttOrOver ME2 MESH_ASY_P2_CONN) (buttOrOver ME3 MESH_ASY_P2_CONN) (buttOrOver ME2 MESH_ASY_M2_CONN) (buttOrOver ME3 MESH_ASY_M2_CONN) (buttOrOver MESH_SY_P1_CONN MESH_SY_P1) (buttOrOver MESH_SY_M1_CONN MESH_SY_M1) (buttOrOver MESH_SY_P2_CONN MESH_SY_P2) (buttOrOver MESH_SY_M2_CONN MESH_SY_M2) (buttOrOver MESH_ASY_P1_CONN MESH_ASY_P1) (buttOrOver MESH_ASY_M1_CONN MESH_ASY_M1) (buttOrOver MESH_ASY_P2_CONN MESH_ASY_P2) (buttOrOver MESH_ASY_M2_CONN MESH_ASY_M2) (buttOrOver ME2 MOM2_term_P) (buttOrOver ME2 MOM2_term_M) (buttOrOver ME2 VP3_ME2_1) (buttOrOver ME3 VP3_ME3_1) (buttOrOver ME3 VP3_ME3_2) (buttOrOver ME4 VP3_ME4_2) (buttOrOver ME4 VP3_ME4_3) (buttOrOver ME5 VP3_ME5_3) (buttOrOver ME5 VP3_ME5_4) (buttOrOver ME6 VP3_ME6_4) (buttOrOver ME2 VP4_ME2_1) (buttOrOver ME3 VP4_ME3_1) (buttOrOver ME3 VP4_ME3_2) (buttOrOver ME4 VP4_ME4_2) (buttOrOver ME4 VP4_ME4_3) (buttOrOver ME5 VP4_ME5_3) (buttOrOver ME5 VP4_ME5_4) (buttOrOver ME6 VP4_ME6_4))
   630. geomConnect(incremental (svia TMV_RDL AL_RDL ME8 MMCTP MMCBP))
error:  Layer 'ptap_p' is not connected.
   632. geomStamp(PWBLK ptap_p)
error:  Layer 'ptap' is not connected.
   633. geomStamp(PSUB ptap)
error:  Layer 'ntap' is not connected.
   634. geomStamp(wel ntap)
error:  Layer 'ttap' is not connected.
   635. geomStamp(TWEL ttap)
error:  Layer 'ptap_all' is not connected.
   636. geomStamp(PSUB_P ptap_all)
error:  Connected input layer 'ptap' is expected.
Abnormal termination at Mon Jun  4 11:16:42 2012
intermediate:   1.15dt 1dw 1.21t 49.1meg 0pf 0.0rss 0r 0w
errno: 0, code: 1
*ERROR* Segmentation violation - run abnormally terminated
File avtsignal.c, line 80, stack:
vdbErrorFunction+139243200()
avtAbortHand+135720304()
killpg+-1218365008()
rcGeomGetNet+137073760()
iliVcodeEval+144348666()
ilxSkillEval+144344644()
_ilErrSet+144284131()
ilErrSet2+144284035()
rcEval+137559472()
evalLayer+137142624()
rcEvalLayer+137138112()
rcParseRelate+137054384()
rcGeomAvoiding+137066288()
rcEval+137559472()
rcProg+137101072()
rcEval+137559472()
rcDrcExtractRules+137297600()
iliLoadPort+144230406()
ilLoad+144229806()
iliLoad+144231541()
ilxLoad+144231605()
iliLoadString+144227664()
ilLoadString+144227762()
ilTopLevelSetString+144283663()
rcCompile+136702128()
vbMain+135510800()
main+135510720()
*WARNING* Translation abnormally terminated!
*****  aveng fork terminated abnormally  *****
*WARNING* /cadence/ASSURA/tools/assura/bin/aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
I can't figure out what's going wrong , i hope anyone can help me.
Thanks in advance,
Stefano
  • Quek
    Quek over 14 years ago
    Hi Stefano
    Would you please try a newer version of Assura (E.g. Assura 41USR2_HF16)? Your current version of Assura314 does not accept
    "incremental" option in geomConnect. This option was implemented in Assura316USR1.
    Best regards
    Quek
  • stefanobre
    Quek,
    Thank you, I'll try the solution you suggest and report the response as soon as possible.
    Sincerely,
    Stefano
  • stefanobre
    Quek,
    I downloaded and installed a newer version of Assura. The one available for me was the 4.1_USR1_HF10.
    I tried DRC and LVS of a simple inverter as i didi the previous times . DRC Runs, while in LVS now i have a different problem:
    If i set DFII in the schematic design source window, LVS seems to fail in finding and convert the netlist file from .cdb to .sdb ,
    it runs indefinitely without giving any result.
    Alternatively, if i choose 'Netlist' and i set the path to the netlist .cdb file , the LVS runs and gives the following errors:
     ERROR     Device 'n_mos_techumc(MOS)' on Layout is unbound to any Schematic device.
     ERROR     Device 'p_mos_techumc(MOS)' on Layout is unbound to any Schematic device.
     ERROR     Device 'dion_techumc(DIO)' on Layout is unbound to any Schematic device.
    I've made a search online and this seems to be a "common" error, but i wasn't able to solve it applying the solutions proposed online.
    In particular:
     1. The technlogy i'm using seems not to give a bind.rul file
     2.  If i set or not in avCompareRules the option " Abort on Unbound Device " the situation does not changes substantially, I still ged the       errors above;
     3. The same if i set or not in netlisting options (when i choose DFII as netlist design source ) "use model property as device name if model in instParameters".
    Waiting for your kind answer,
    thanks
    Stefano
  • Quek
    Hi Stefano
    I think there is a slight misunderstanding. "Netlist" input mode refers to either cdl, spice or verilog netlist and not CDB schematic data. Your current version of Assura (41USR1) is still quite out-dated. It would be great if you can try ver 41USR2_HF16 to see if it still hangs.
    Best regards
    Quek
  • stefanobre
    Hi quek,
    Thanks, I got the point. Unfortunately i couldn't get a newer version of assura, but i managed to make things work with the Assura 4.1 HF10
    exporting the CDL netlist for every cell and then running the LVS .
    Thanks for all your answers,they were useful,
     Best Regards,
    Stefano
