  3. Can't run virtuoso in IC6.15
  • Subscribers 136
  • Views 5371
pyohayo
pyohayo over 14 years ago
After IC6.15 installation (under RHEL5) attempt to run virtuoso failed.
Here is error message:
bin/ksh: bad interpreter: No such file or directory
I tried to find ksh package, but yum found nothing.
Where is a problem ?
Thanks in advance.
Pavel.
  • Quek
    Quek over 14 years ago
    Hi Pavel
    It simply means that you need to install ksh package. You can use the following cmd to do a more complete check on your system:
    terminal>$CDSHOME/tools/bin/checkSysConf IC6.1.5
    Best regards
    Quek
  • pyohayo
     Hi Quek,
    Thanks for response. You were right - syscheck confirmed abscence of the ksh package. Here is output:
    Validating PACKAGE requirements.....9 to check
    #   PACKAGE          Release    Build          Installed       Status  Info
    1   glibc            2.5        24             2.5-42.el5_4.3  PASS
    ->  'GlibC'
    2   elfutils-libelf  0.125      3.el5          0.137-3.el5     PASS
    ->  'Libelf Library'
    3   mesa-libGL       6.5.1      7.5.el5        6.5.1-7.7.el5   PASS
    ->  'Mesa libGL Library'
    4   ksh              20060214   1.7            -               FAIL    Package not installed.
    ->  'ksh'
    5   compat-readline434.3        3              -               FAIL    Package not installed.
    ->  'Readline Compat lib'
    6   openmotif22      2.2.3      18             -               FAIL    Package not installed.
    ->  'RHEL 4 openmitif'
    7   libXp            1.0.0      8.1.el5        1.0.0-8.1.el5   PASS
    ->  'libXp'
    8   gdbm             1.8.0      26.2.1         1.8.0-26.2.1    PASS
    ->  'libgdbm.so.2'
    9   glibc-devel      2.5        24             2.5-42.el5_4.3  PASS
    ->  'GlibC-devel'
    Validating FILE existence .....0 to check
    Validating NOTFILE existence .....0 to check
    Configuration checks failed, status is: FAIL
    This system does not have the correct packages to run IC6.1.5
    But when I try to install ksh, system tell me that there is no such package:
    [root@localhost IC615]# yum install ksh
    Loaded plugins: rhnplugin, security
    Setting up Install Process
    No package ksh available.
    Nothing to do
    Regards.
  • Quek
    Hi pyohayo
    Perhaps you can try searching for ksh rpm packages on the Internet. : )
    Best regards
    Quek
  • pyohayo
     The problem is resolved. Thanks.
  • JoshOp
    JoshOp over 10 years ago
    Hi Quek, can you please detail how the problem was resolved? I have the same exact problem with the same exact outputs as you showed in post#1, I have yum installed ksh and openmotif, but am unable to find "compat-readline434.3" . Googling for compat-readline, I see that there is such a thing as "yum install compat-readline" but that command shows there is no such package as compat-readline for me. What did you do to resolve the compat-readline issue? Thanks for your help.
  • Quek
    Quek over 10 years ago
    Hi Xiaoxi
    "yum" is the package installer on linux and it requires a repository in order to work. E.g. you will be able to use it if you have a redhat account. If you are using Centos, you can use the following package:
    http://tinyurl.com/guj4sco
    Best regards
    Quek
