  3. Phase Noise Output Expression using Harmonic Balance in...
  • Subscribers 132
  • Views 14946
Phase Noise Output Expression using Harmonic Balance in Spectre?
yayla
yayla over 14 years ago
 I am runnig Phase Noise simulations. For this, I am trying to write an output expression in Spectre. To do that, after running "hb" and
"hbnoise", I am clicking Add to Outputs expression from Direct Plot which is
Expression: "list(3.00e+01 1.858e+03 -4.63e+01)"
The problem is that when I try to plot the waveforms using this expression either from Calculator or Plot Outputs in ADE one more time, I couldn't plot them although there is no problem plotting from Direct Plot by choosing Phase Noise under hbnoise for the first time.
 I will really appreciate if you could have any idea about this issue.
 yayla
