  3. about CDL import/export question
  • Subscribers 132
  • Views 1382
Jiangs
Jiangs over 14 years ago
1.In the PDK , there are two parameters about width:1.w(total width) 2.fw(figure width)
   In the map file , I can only define: propMap := w w or propMap := w fw
   w:MOS's width in the CDL files; w fw:MOS's width in the PDK
   I want to define w=w=fw, how to realize?
2.In the CDL files w=5u, but when I import the CDL file, in the schematic w=5E-6.
   When  I export the CDL file, as is the case with import.
   I want to realize w=5u , no matter import into the schematic  or export  to CDL file.
   How to realize?
   The Cadence versions 5.10.41.500.6.136
Thank you
Jiang
  • Quek
    Quek over 14 years ago
    Hi Jiang
    In the instance property form, if w is calculated from fw, then you should map cdl w to pdk fw and then use the callback triggering skillscript from COS solution 11018344 to synchronize the value of w to fw.
    After re-triggering the callbacks, does the schematic values change from 5e-6 to 5u? I can't remember if the script has such an effect. If not, perhaps you can resolve the units problem in the cdl file with a perlscript.
    Best regards
    Quek
