  3. multi-Core simulation with Ultrasim?
  • Subscribers 133
  • Views 16725
01farhad10
01farhad10 over 14 years ago
I was wondering if it is possible to do multi-Core simulation (multi-threading) with Ultrasim? I looked over the Ultrasim User Guide but I didn't find anything relevant.
  • Quek
    Quek over 14 years ago
    Hi 01farhad10
    You can use "ultrasim +multithread". Please execute "ultrasim -help" in a terminal window. : )
    Best regards
    Quek
  • 01farhad10
    Thanks Quek for your response. I ran "ultrasim -help" in a terminal window but it doesn't show the +multithread option. I'm using ultrasim version 7.2.0 32bit (08/27/2010). Is my version outdated or there is another reason I'm not seeing this option?
    Yes, it's too old. There has been MMSIM10.1 and MMSIM11.1 since then (a change of numbering scheme meant there was a big jump from 7.2 to 10.1).
    The latest extends the modes that support multi-threading, so I'd suggest using 11.1
  • 01farhad10
    ok, then it seems I need to ask our administrator to update MMSIM.
    Thanks Andrew
