  3. Undo pcell
  • Subscribers 133
  • Views 15483
Undo pcell
RVERP
RVERP over 14 years ago
 Once I've launched Pcell in cadence virtuoso and I save, my layout gets recognized as pcell.  Is there any way to go back to the "normal" layout, so I can use edit in place again?
    Open the layout cellView in question, and do three things:
    1. In File->Properties (the Edit CellView Properties - often on shift-Q) go to the property page, and select the viewSubType property, and hit Delete.
    2. In the CIW, type dbUndefineProc(geGetEditCellView())
    3. Save the cellView
    That should fix it.
  • RVERP
     Works perfect, thanks
