  3. Practical limit to the number of elements in a vector port...
  • Subscribers 132
  • Views 14741
Practical limit to the number of elements in a vector port in VerilogA
Herge
Herge over 14 years ago
With the nice support for port vectors, parameter arrays and FOR loops, one can write module code for a theoretically unlimited number of ports. I have built a module where the number of ports is parametrized with a pre-processor variable.
I am wondering what are the practical limits to the number of ports of a verilogA module ?
What is the limit to the number of iterations in FOR loops ?
My module is meant to simulate parasitic bipolar interactions in the substrate. In our chips we easily have several 100's of junctions. We've set ourselves a target to be able to handle 1000 junctions. This means 2 port vectors with 1000 elements (plus an additional 1000 internal nodes).
 We have already checked that a mesh with >10k instances of 4-port devices generated by the same module converges smoothly in SPECTRE.
We have not yet checked that an instance of the 2K ports module works... Should we expect (bad) surprises ?
    I have no idea. I doubt there's any simple or hard number - it's more likely that you'll hit performance limits in some situation, and that's going to be very dependent on precisely what you're doing.
